Question Surround triple monitor different heights
aidandargue
11
I have 3 1920*1080 monitors on a stand although they do not line up, I have used the windows and Nvidia software to virtually change the height, but for surround is there anyway to do this and have the moniters callibrated to the same height (any possibilities at all)
Is the plate that mounts to the monitor fixed to where it mounts to the stand, or is there some adjustment there? Could you possible remove the monitors from the mounting plate, and then rotate the plate so that its top is now on the bottom? What exact mounting stand do you have?
What size are the monitors?
And can you raise the center VESA mount?
center I'm having problems with - https://www.samsung.com/us/computin...ming-monitor-with-quantum-dot-lc24fg73fqnxza/
outer two - https://www.samsung.com/us/computing/monitors/curved/samsung-24-curved-led-monitor-lc24f390fhnxza/
(the center VESA mount is now under the dual arm and raised to the maximum as the V shape of all 3 monitors, all though not in line, looks better than an upsidedown V
but either way, they are not at the right heights)
