M Matteo De Vellis Reputable May 9, 2015 242 0 4,710 Jun 20, 2015 #1 what are the specs of the h140x/h220x/h240x pumps (flow rate and head pressure)
galeener Distinguished Apr 9, 2010 1,256 0 19,660 Jun 20, 2015 #2 swiftech .com for specific details youy can visit the forums or use their support email they will answer all your questions. Upvote 0 Downvote
M Matteo De Vellis Reputable May 9, 2015 242 0 4,710 Jun 20, 2015 #3 galeener : swiftech .com for specific details youy can visit the forums or use their support email they will answer all your questions. I couldnt find it on the swiftech website, just tell me if u know. Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Jun 20, 2015 #4 The unit uses the MCP30 pump from Swiftech, however I havent been able to pin down the specs on it. Upvote 0 Downvote
M Matteo De Vellis Reputable May 9, 2015 242 0 4,710 Jun 21, 2015 #5 Gam3r01 : The unit uses the MCP30 pump from Swiftech, however I havent been able to pin down the specs on it. just found it, its only 6L per minute/1.6 Gallons per minute Upvote 0 Downvote
