Swiftech H20-220 Apex Ultima Liquid Cooling Kit?
thanks for the great reply, right now water cooling kit is my second choice for my new rig, its either a water cooling kit or 2 5950's in crossfire. i have ALWAYS wanted to try water cooling over air cooling. doing research and more research, i just dont know if i want liquid cooling or 2 5850's, but thanks again for the options, take it into consideration, thanks
Water is great, it can be a pain if not done right without research.
OP: You might want a bigger rad if your really pushing the OC and want the very best temps with quiet fans.
You see the solved guide at the top of this subforum?
yea i did, i actually read it for the 2nd or 3rd time yesterday
just in case i cant find them, can you post some links?
