G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Does synchronization makes the computer faster. I mean if I make the
speed of the FSB running at speed similar to the memory speed. For
example if I have DDR200 then I will make sure I will have a CPU with
FSB 400 and the motherboard should support FSB 400. Is this the
ulitmate goal of a computer designer in term of the speed?? or
Synchromization is not important??
Any help would be appreciate it .. thanks..
