byte0215 :
bailojustin :
byte0215 :
bailojustin :
Yes. As long as its not directly connected to the PSU, any sys fans you can control aslong as they are 3 prong and plug directly into your MOBO
i can control them through bios or software?
Your choice, both. You can control using software, or your bios if it offers that option.
what about the heatsink fan connected to cpu pin? can i control it also?
the heatsink fan if you get a good 4 pin will have whats called PWM pulse modulation, and it will allow you to change the rpms and everything, or set it to auto, the cpu fan has the most customization when it comes to speeds
