Hay Guys I'm at a loss now,
My problems started when windows 7 auto upgraded to windows 10. My rig wouldn't be able to restart and load back into windows. After a long, long disscussion with Microsoft they determoned my ASUS Nvidia GTX 570 was not compatable with Windows 10, as well as my monitors dirvers did not support 10. So after a lot of just dealing with it I finally replaced my Graphics Card with a ASUS GTX 1080 Ti, and my monitor with a ASUS PG348Q.
After installing the New Card, ive had a ton of BSOD which forced me to "Reset" Widows (took 3 attempts). My BSOD errors ranged from:
IRQL_NOT_LESS_OR_EQUAL
SYSTEM_SERVICE_EXCEPTION
EXCEPTION_ACCESS_VIOLATION
PAGE_FAULT_IN_NONPAGED_AREA
KERNEL_SECUTITY_CHECK_FAILURE
MEMORY_MANAGEMENT
DRIVER_CORRUPTED_EXPOOL
I beleve alot of this has to do the the "Kernel Enhanced Driver", but asus dosen't have any new versions available. I've uninstalled and reinstalled it several times. I also downloaded and reinstalled every available driver from asus.com
I've installed REGCUREPRO and REIMMAGE to fix any remaining windows issues sense windows isnt able to fix its self in my case. Now the BSOD has become rare. maybe once in 2 weeks time. however games like WOW crash all the time.
When my computer get restarted my ASUS Nvidia GTX 1080 Ti gets automatically disabled by windows, and a defult CPU baised driver is utilized. So, I have to reinstall it, restart and its good. but if i restart my computer again it kicks my GPU back to Disabled in Device Manager.
I'd love to find the cause of the GPU becoming disabled, as well as the system crashes so i can return to using my computer normally. Does anyone have any ideas? I've been leaning tward the opinion that i simply have some hardware or driver inconpatablity ether in windows 10 or between the relationship between the mobo and the gpu. or maybe its the Kernel Enhanced driver (OSD). but if i unstall it my system becomes unstable, so it seems it required... IDK...
My rig:
INTEL i7 2700K @4.2Ghz OC
ASUS P8Z77-V Deluxe
INTEL 520 240GB SSD (System is loaded on this one)
1.5 TB WesternDigital Black
Corsair Vengance 16GB (4GBx4) @ 1600
Corsair HX1050
ASUS Nvidia GTX 1080 TI (Replaced a ASUS Nvidia GTX 570)
Corsair Hydro H100
4 120mm Gentle Typhoon's
ASUS PG348Q
ASUS MX279X
Sennheiser GSX 1000 W/ GSP 600
MEMORY_MANAGEMENT
My rig:
ASUS P8Z77-V Deluxe
Corsair HX1050
Corsair Hydro H100
ASUS PG348Q
ASUS MX279X
