System Builder Marathon, June 2012: $1000 Enthusiast PC
I personally think they went a little TOO overboard on the GPU. Sure, it'll tear through games... but at 4GB of RAM, a non-overclockable i5 CPU, and a P67 motherboard... well... meh...
I realize the SBM is sponsored by Newegg, so that means they're only able to get what they can from Newegg?
Because if not, I would posit that the i5-2380p is a better CPU choice than the i5-2400:
1) You've not got a huge need for the IGP, what with the 7970 (I could see it could still have use, but I don't think it would be that helpful)
2) From what I've read on Newegg's page for the 2380p (which they no longer sell), the 2380p is a great overclocker (up to 4.5Ghz according to one reviewer)
3) It costs the same as the 2400, with the same stock clocks
Apart from that, I think it's a pretty solid build. A little too much corner-cutting compared to what I would've chosen, but I'd probably put together something rather standard and boring.
[citation][nom]mayankleoboy1[/nom]not criticizing, but this build looks like a half-hearted attempt. Basically the whole article tests the improvements of a single channel over a dual channel RAM.[/citation]
Yeah I totally agree, I would have loved to see a 3570k and a gtx 670 because those two seem like the popular choice right now. Who sets this budget anyways? "We didn't wan't to go over" umm is there like a slow painful death if you go over the budget or what? Set the budget higher then. Hope the next round of these is better.
I'm not quite sure how I should respond to both of the system builders comment section from this week. Gtx 670 wasn't available, we know. Stop beating this dead horse. Its just like last quarter's waterfall of "why no 680????"
As of right now at the time of this post, the sapphire 7970 o/c on newegg is at $480. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102982 So i can only assume whatever price hike has been dealt with?
Good job on making a computer perform about the same for $250 less! I'm sure if I was to build a computer right now this would give quite a bit of breathing room. Not everyone has quarter of a grand to throw around.
Downside is it does feel like you guys ran outta ideas on new combinations. I think I'd be kind of interested in either a SLI config 560 ti or 7850s. But the 7850 would've pushed it past budget I think. I'd still vote on the SSD though!
Not sure if mentioned, But personally I would've gone with a newer chipset mobo even if your using a sandy-bridge cpu, if you compare features what you get with a h77 motherboard for like $80 is very compelling, intergrated USB 3.0 means you get this at much cheaper prices then before. And you don't need an overclocking chipset if your not buying a k processor. That and even on a board with 16x4x Pcie layout, 4x PCIe 3.0 = 8xPCIe 2.0 which means you can go for lower end mobo and still have viable SLI/Crossfire options (if you use a Ivy-bridge CPU).
I get that this was an attempt to recover from last quarters ram debacle, but essentially you chose an overpriced GPU, and overpriced and outdated motherboard and a last-gen CPU? It's just not a balanced build, far to much budget wasted on that GPU and I don't know anyone these days spending a thousand bucks and not picking up an SSD, agility 3 60gb drive's are perfect for entry level boot drive and you can find the thing for around ~$70 which could've easily been saved by a more appropriate choice of parts.
This system is not balanced.
The point of a GOOD pc, is to have total system balance. Balance, as in the cpu,gpu, etc. are all in the same performance range. In this case, it really isn't balanced.
[citation][nom]amuffin[/nom]This system is not balanced.The point of a GOOD pc, is to have total system balance. Balance, as in the cpu,gpu, etc. are all in the same performance range. In this case, it really isn't balanced.[/citation]
Yeah. This looks like a PC built by someone who only wants maximum fps in Battlefield 3 and wasn't concerned about anything else. It will do but I would change pretty much every part if it were my real money.
4GB of RAM? You can have +4GB for +$20.
i5 2400? You can have the 2500K for +$20.
AMD 7970? Well whoever wins this thing will certainly be lucky, but it is half the cost. This card could have been reduced to one that is lower-end, distributing the cost to the aforementioned RAM and CPU, with a better case and a modular power supply from SeaSonic (there is one which can power this machine for about $60 currently).
I agree with those who think this combination was simply whipped together. A 7870 can max out a $250 monitor, for example. Why do you need such a high-end card for this?
I got a z68 gigabyte board from newegg for about 90 bucks, with the ssd slot thingy (I know, I forgot the name of the port) I would think that would have been a better pick since it is better for overclocking....also cheaper so you could have gotten a 2500K, like I did lol. My whole build costed me about 450 plus and I have 8 gigs of ram @1866. If I went with cheaper case you probably could have still squeezed in that 7970 comfortably.
It seems to me that a better way of dealing with the lower price ceiling would be to drop the video card to a 7850, which would save $220 over the 7970. That could easily cover an overclockable processor, SSD boot drive and a full 8gb of RAM. The 1080p gaming results should be easily playable. While the 2560x1600 results wouldn't be as good, I don't see how someone building a $1000 system would be willing to drop just as much on a monitor.
What a horrid case! The graphics card sort of torqued at an angle just looks kludgy, and I'd be concerned about a casual bump rending the PCIE slot out of the mobo or some other serious damage.
As to balance, that depends. For a "Gaming" PC, I think the CPU/GPU balance is fine. For an "Enthusiast" build, however, I agree with the other posters that too much was spent on the graphics card and not enough elsewhere. One way to judge a build is to look at it and ask "how could this be better?" Unfortunately, I think this machine has too many items on that list.
Great build for $1000, made the correct decisions on what to drop and what to keep for the maximum performance at this price.
The case may not be to every ones taste and it did show it's weakness with the length of that graphics card, but who hasn't had to bend something in their case to make something fit? If you haven't you're missing out!
The one lesson in this build is that SSDs many be fast and have their place on certain applications but if you just want to game and get the best $/performance spend the cash on other aspects of your system, or buy your system then add one in later.
the intel cooler is ok for temperature, that's a good news
what about noise?
I think coolers are very expensive, but if the intel cooler does the noise of a plane, it's not even a choice :/
