dompadidodadollidado
I really like the comparisions and for now I've decided to buy something similair to the low budget pc. I have a couple of questions though which I hope I can get some help with.
1) The article claimed that the AMPO ram had great overclocking capabilities. The stores that I buy my stuff from in Sweden don't retail AMPO. I chose between:
OCZ, Corsair, Kingston, Crucial and TwinMos.
Which should I choose to replace AMPO with? Which is the better for overclocking. Or should I just buy a more expensive RAM, as I don't really have a tight budget, but still want good performance / dollar (or swedish cown). If it makes any difference I'm planning to buy 4GB RAM.
2) What kind of power should I be looking at. I don't really understand the 39amps discussion so if you could just point me at the right direction.
3) I'm planning to run Windows Vista, is there a way to clock the 8800GTS in Vista as I read that AtiTool isn't supported? Is it necessary for me to overclock the Graphic card (read below)?
4) Will the system support a dell 30"? Not for gaming at highest resolution as I spend most gaming in windowed mode as I like to be able to other stuff in the meantime. I other words, I don't really do FPS but rather experimental games, strategy games and developing my own. I do occational Photoshop creations. And want to be able to have lots of stuff going on (why else a huge display?).
5) actually, Should you recommend a 8600GTS instead, considering my demands, or should that totally mess me up when I run max resolution in Vista and try to do lot of stuff? The 8600 has support for HD which I plan to be watching alot, especially x264.
6) got a bit carried away, was trying to keep it short. Final question. Would you say that what i'm looking for is realistic or should I aim for a Q6600 and skip the whole oc part?
*Hoping for some help*
Thanks
Thanks
