TeraMedia
Pardon my ignorance, but does the P67 chipset allow for the use of the dedicated codec hardware on Intel's CPUs? I thought you had to use either the lower-end chipset that includes video out, or a Z68. If this is accurate, then Don's MB selection also hampers the performance and feature set of the system as far as video enc/dec and other tasks are concerned. I know that the 7970 can offload the CPU in theory... but it does not necessarily do so any faster, nor with as little power consumption or image quality, as Intel's implementation. I don't know whether image quality is equal or better with 7970-assisted video processing vs. the on-die Intel codec. I also dont' know whether power consumption would be higher or lower (probably higher...), and finally I don't know what will happen if/when AMD enabled their own on-GPU codec chip. But unless the 7970 can equal or better the power/performance/quality of the Intel codec, then that at least is a meaningful loss caused by the MB selection.
