James Mason
RedJaron :
James Mason :
(I just wanna say i like the look and performance of this build)
Thanks, I appreciate that. I'm not saying everyone has to agree with me. I welcome good, rational debate. Complaining about things one person didn't say and about rules they didn't invent is not rational or productive
Is there anything you would have changed in this quarter? And if so, why?
Besides making the jump to Skylake (with also maybe a chance at OCing a locked i3, and DDR4) which you said you couldn't do, and thus also getting a lower wattage PSU (less weight and heat) I don't think there's really anything that'd be changed, but that'd likely be more expensive anyways. Weight is typically not a factor for a PC, but since it's designed to travel it's definite consideration.
Case wise for a "Lan box", i'd also consider how easy it is to carry under your arm maybe, with the previous Elite 130 maybe being easier to carry than the V1, but idealy a case with a handle would be best, but all the cases with handles i've seen have bad ventilation.
I'm typing this response on almost the same PC you built
i3-4130
8GBs 1600mhz
GTX 750ti
CM Elite 130
On the topic of "better for a Frequent LAN events" I kind of wish you guys could have have some $800-900 laptops with 960/970Ms to compare it with. They may be an "easier" solution than a whole computer while still performing "adequately" (but not beating).
Like for other SBMs maybe, have systems designed to do X at X dollar amount, what are your options, if you sacrifice performance for ease of use is it still acceptable, ect.
This was a pretty tricky and unique SBM though.
