System Builder Marathon: The $5,000 Extreme PC
[citation][nom]xx12amanxx[/nom]Nice article!I wish i could own a rig like that,but it would be that or a 383 stroker for the F-body..lol I can dream cant I?[/citation]
383 strokers are for copycats. Basically, too many bad 400 blocks and people found a cheap way to re-use the cranks to make their 350's bigger. If you have THIS kind of money, you'd might as well go BIG BORE too. Maybe a bowtie block? At any rate, you'll win more races with a real 400 (or larger custom size) so long as the block is good.
It is interesting to note on Page 14. On the Sandra XII Multimedia test the Core i7 965 @ 4.2GHz scored 486,971, while the i7 920 @ 4.0GHz scored 386,867. The difference was 200MHz and made such a large difference. Did the Intel SSDs influence such a large gain in performance or the DDR3 @ 1800MHz or perhaps a combination of both?
The 965 has a higher-bandwidth QPI link, so it should be good for boosting at least a few synthetic scores.
BAH!! Why is it always Intel? Only Servers and people that wish they MAC should use Intel stuffs.. Who else is going to use all of it's features? Not gamers, that is for sure!! Like a gamer is going to spend the extra $$ for ECC memory and not spend it on more important stuff like a GC or a great board. That and an economy minded PC buyer will go AMD anytime, more bang for the buck...
Also, Ati is better a better card, for linking I mean. The support may be crap, but it is usually worth it to get them! 4850 X2, Water cool one and watch the clock go through the roof!
Intel is the fastest thats why...This is supposed to be an uber rig.
Ya crashman thats the problem i dont have that kind of money..lol A fresh stock rebuild bolt on's and spray will have to hold me off until better times!
[citation][nom]xx12amanxx[/nom]Intel is the fastest thats why...This is supposed to be an uber rig.Ya crashman thats the problem i dont have that kind of money..lol A fresh stock rebuild bolt on's and spray will have to hold me off until better times![/citation]
I spec'd out a friend's 406 C.I. mouse a few years ago and he got through under $4500 with aluminum heads and a roller cam!
Great article!
HOWEVER, Should have used an Antec1200 for that much coin on the case. I have one at home using water cooling and its so much easier than any other case I've used to date. Cheaper too, in this instance.
[citation][nom]_horse[/nom]Great article!HOWEVER, Should have used an Antec1200 for that much coin on the case. I have one at home using water cooling and its so much easier than any other case I've used to date. Cheaper too, in this instance.[/citation]
I've owned both, the Cooler Master is a nicer case. I mean, we're just throwing opinions around now, right?
But the Cosmos S is far more portable, and it fits the big radiator perfectly. In fact, it's the only stock case to fit that radiator properly.
With a build like that you guys should have tryed to set Crysis with 16 AA!
well it probably wont be playable but it would just be neat to see.
[citation][nom]Crashman[/nom]I've owned both, the Cooler Master is a nicer case. I mean, we're just throwing opinions around now, right?But the Cosmos S is far more portable, and it fits the big radiator perfectly. In fact, it's the only stock case to fit that radiator properly.[/citation]
Thats true, but I didnt know we were going for portability here, especially with a liquid cooled system.
Nice article.
Question for the writing staff:
Have you thought about taking all your review statistics, and assembling an "uber system" based on the best parts based on what you have found in your review tests?
Just curious. I don't remember that ever having been done before here. And for $5,000, you surely could afford to throw together all of the top notch parts into a system for kind of a "what happens when you put all the best parts together" article.
Now you guys have me itching to build a new system already...and I just built one back in September!! lol
That is a really good question too:
With the width of the video cards, where would you plug in a soundcard? Does it use the 3rd PCI-E x16 slot?
Just curious. I've always noticed how the ATX motherboard size standard hasn't shifted to grow with the growth of the size of components, such as video cards and component heatsinks.
Limited room bites. lol
[citation][nom]cah027[/nom]Why not 3 liquid cooled 285's. Maybe drop the Blueray and or go down to a 920 in the next one. Keep the SSD's.SSD's are fast but the only benchmarks they matter in are the ones that don't count (synthetics)[/citation]
Would have been better off (performance-wise) to go with the Swiftech 220 kit to start with...you wouldn't need to upgrade the CPU block, you get a better pump and you could use the dual radiator along with the additional 320 to watercool the GPU's by adding them to the loop. If you are going 'extreme' this isn't that much more above your budget and you would get far more cooling performance.
Remember when this site actually have good articles and reviews? No one cares about a $5000 PC rig that is unattainable for the even the hardcore PC enthusiast
