N novacbane Honorable May 12, 2013 63 0 10,630 Jun 18, 2013 #1 Is the PSU compatible with the radeon 7870? Since on sapphires website, it shows that the 7870 requires 2 power pci connectors and xfx only has 1? Also, if any other component in this build wont be compatible. Please let me know.
Solution Dark Lord of Tech Jun 18, 2013 Yes , and don't forget to choose best solutions when you open question threads.Thanks for posting and nice build.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,625 1,783 159,590 Jun 18, 2013 #2 Needs to 6 pins , what XFX is it? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,625 1,783 159,590 Jun 18, 2013 #3 http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013 XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply This will run it ^ Upvote 0 Downvote
N novacbane Honorable May 12, 2013 63 0 10,630 Jun 18, 2013 #4 My mistake for not putting the link. How about this? http://pcpartpicker.com/p/16Vsg Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,625 1,783 159,590 Jun 18, 2013 #5 Yes that's the same one i linked , it has the right connections and power to run a 7870 on your system. 1 x 6-Pin, 1 x 6+2-Pin < your all set Upvote 0 Downvote
N novacbane Honorable May 12, 2013 63 0 10,630 Jun 18, 2013 #6 Alright thanks, is everything else compatible? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,625 1,783 159,590 Jun 18, 2013 Solution #7 Yes , and don't forget to choose best solutions when you open question threads.Thanks for posting and nice build. Upvote 0 Downvote Solution
