Hi,
I recently updated my CPU and GPU. Since doing this I have been experiences crashing when i play most games. When a game crashes it will normally freeze then shut down and revert back to the desktop or it will freeze and I will have to kill the programme in task manager.
I also have had the odd blue screen with the "your PC ran into a problem" message. This issue only come after i have tried to play a game and the game crashes.
I don't have any issues when I use the PC for general tasks like internet browsing, playing media (Films, Music ect). I also have no issues playing games that are not that demanding like Hearthstone.
I have tried reducing the graphic setting on the games crashing my PC and it has made no difference.
I have updated my BIOS and drivers as well as removing the old drivers.
I thought the issue was windows so i did a fresh install of windows but the issues still remained.
I have bench marked the GPU with FurMark, Valley Benchmark as well as 3D mark. and I have had no issues.
I ran Memtest86 and I got 37 errors. all the errors were in test 6. I ran the test a second time and got 30 errors this time but still all in test 6.
The only thing I can think that might be the issue is either the PSU or the Memory.
If anyone can help it would be much appreciated.
My Specs are
Processor - AMD FX8300 3.3GHz
Motherboard - Sabertooth 990FX
Graphics Card - Sapphire RX480 Nitro+
RAM - 8GB
Harddrive - 1 x 60GB SSD
1 x 500GB
1 x 1TB
OS - Windows 10
PSU - 550W
Here is the result summary from the Memtest (Second test I ran)
Test Start Time 2017-02-16 22:47:50
Elapsed Time 1:10:42
Memory Range Tested 0x0 - 23F000000 (9200MB)
CPU Selection Mode Single: CPU # 0
# Tests Passed 11/12 (91%)
Lowest Error Address 0x1BD2C0D80 (7122MB)
Highest Error Address 0x1BF3E0D98 (7155MB)
Bits in Error Mask 00000000FF000000
Bits in Error 8
Max Contiguous Errors 1
Test # Tests Passed Errors
Test 0 [Address test, walking ones, 1 CPU] 1/1 (100%) 0
Test 1 [Address test, own address, 1 CPU] 1/1 (100%) 0
Test 2 [Address test, own address] 1/1 (100%) 0
Test 3 [Moving inversions, ones & zeroes] 1/1 (100%) 0
Test 4 [Moving inversions, 8-bit pattern] 1/1 (100%) 0
Test 5 [Moving inversions, random pattern] 1/1 (100%) 0
Test 6 [Block move, 64-byte blocks] 0/1 (0%) 30
Test 7 [Moving inversions, 32-bit pattern] 1/1 (100%) 0
Test 8 [Random number sequence] 1/1 (100%) 0
Test 9 [Modulo 20, ones & zeros] 1/1 (100%) 0
Test 10 [Bit fade test, 2 patterns, 1 CPU] 1/1 (100%) 0
Test 13 [Hammer test] 1/1 (100%) 0
Last 10 Errors
[Data Error] Test: 6, CPU: 0, Address: 1BF3E0D98, Expected: 7F000000, Actual: 80000000
[Data Error] Test: 6, CPU: 0, Address: 1BF3E0D90, Expected: 80FFFFFF, Actual: 7FFFFFFF
[Data Error] Test: 6, CPU: 0, Address: 1BF3E0D88, Expected: 7F000000, Actual: 80000000
[Data Error] Test: 6, CPU: 0, Address: 1BF3E0D78, Expected: 80FFFFFF, Actual: BFFFFFFF
[Data Error] Test: 6, CPU: 0, Address: 1BF3E0D70, Expected: 7F000000, Actual: 40000000
[Data Error] Test: 6, CPU: 0, Address: 1BF3E0D68, Expected: 80FFFFFF, Actual: BFFFFFFF
[Data Error] Test: 6, CPU: 0, Address: 1BF3E0D60, Expected: 80000000, Actual: 40000000
[Data Error] Test: 6, CPU: 0, Address: 1BF2C0D98, Expected: 80002000, Actual: 00002000
[Data Error] Test: 6, CPU: 0, Address: 1BF2C0D90, Expected: 7FFFDFFF, Actual: FFFFDFFF
Thanks
My Specs are
RAM - 8GB
1 x 500GB
1 x 1TB
OS - Windows 10
PSU - 550W
Bits in Error 8
Last 10 Errors
Thanks
