[SOLVED] System crashing to black screen, and all fans go to high speed
JasonTD
36
I'm having a problem where my system crashes to a black screen, and all the fans (all case fans, CPU fan, and GPU fans) suddenly kick into high gear, blowing loud until I manually hit the reset on the case. Once I reset, the system reboots and runs normally. Occasionally it will crash again a little later, but it usually runs fine the rest of the day after that restart. This problem has been happening once or twice a day, and I've noticed it happens more often when I'm watching a video or playing a game, but I think it has happened when I wasn't doing those things as well.
Strangely, this exact same problem happened with this system almost a year ago. I tried to troubleshoot the crashing for a couple of months last summer. It suddenly cleared up without my having done anything that I'm aware of to resolve it. I thought everything was fine, but now it's started back again. It's certainly frustrating, and I'd appreciate some direction in identifying what's causing the issue and resolving it.
I'm not sure where to start or what information would be helpful for diagnosing this, so any help is appreciated.
Thank you!
full system spec? include make and model of the psu
check cpu/gpu temp?
Here are my main system specs:
EVGA GeForce GTX 1070 SC GAMING ACX 3.0
Intel Core i5-3570K CPU @3.40GHz
ASRock Z77 Extreme4 LGA 1155 Intel Z77 Motherboard
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Corsair CX Series 750 Watt 80 Plus Bronze Certified Modular Power Supply
Cooler Master HAF XM Case
Do you need any additional info for that?
According to CoreTemp, my cores right now are at the following temperatures:
0: 28ºC (max 39º)
1: 29ºC (max 41º)
2: 33ºC (max 45º)
3: 29ºC (max 41º)
According to GPUTemp, the GPU right now is at 39ºC
Thanks in advance!
Just following up here in case someone else has this same problem. It turned out that the issue was with my graphics card. The thermal paste on the GPU either had gone bad or wasn't applied properly to begin with. Either way, I opened up the card, cleaned off the old paste, applied a new dot, and put it all back together. Since then, I haven't had any crashes.
