Question System doesn't power on sometimes
Dec 29, 2019
My system does not power on sometimes on morning while it perfectly works fine after I re-plug my wires or re-fix rams. Although when i plug it initially, my controller attached with system lights up which indicates that PSU is supplying power to it but doesn't start the mobo. I replaced my mobo but still same issue. What could be the issue?
System Specs:
Core i5-4690
Ram 8gb HyperX 1600mHz
MSI R7 250 OC 2gb edition
Antec 500W PSU
1Tb, 250GB HDD, 128GB SSD
It sounds like the power supply is starting to fail.
Your symptoms certainly seem like this is the case.
When mine started to fail it still showed power to the USB ports like yours does although it sometimes didn't start up the PC.
It has worked fine ever since I replaced the power supply.
Andy
Reactions: nomi13 and SamirD
Andy
Thanks for your early response. I replaced my PSU today, its working fine for now. Will update it sooner if it works fine for couple of days.
