Hi, I need your help for my system fan speed.
Basically, I just purchased new case "Montech Air X white" with ARGB fans/controller. So I moved parts from old pc (Zalman Z9 case) to the new one.
Now I got some weird issue on system fans connected to built-in fan controller.(ARGB + 4-pin FAN) I believe that I connected everything right. Then I noticed the fan noise is quite loud so I lowered it in BIOS(PWM %) and it seemed to work in BIOS(no noise). However, after booting my PC, the fan speed changes to 100% (by its noise) while I set the speed in BIOS to 10~20%.
Bios shows system temp between 40~45C while I was setting fan speed, and I set 10% speed until 80C. I do not believe my system temp goes up to 80C right after booting.
Any idea about this issue? Fan speed can be set in BIOS and works in BIOS, but changes to 100% after booting.
System info
Windows 10
Mobo: Gigabyte Z390 (this one does not have ARGB header, so I left ARGB connectors unconnected)
Case : Montech Air X white
Fan connection:
---- Add ----
I just noticed that when I completed turn off my pc and start it, those system fans run at bios settings. However, if I restart my pc (either at windows or bios), fan speed changes to 100% with loud noise.
System info
Windows 10
Fan connection:
Fan settings in BIOS3x fans w/ ARGB to built-in controller hub (pre-installed)
4-pin connector from built-in hub to SYS_FAN 3 on mobo (4-pin header)
SATA power to PSU (Seasonic 750W Gold 80+)
Temp sensor: System 1 (Just temp. sensor, not fan #)
Fan #: System 3 (edited)
Mode: PWM mode
10% until 80C / 30% at 85C / 100% at 100C
---- Add ----
