System Freeze when hyper threading enabled
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello,
I recently upgraded my motherboard to Intel D875PBZ with
Pentium 4 3.0G CPU.
After the installation of the motherboard, I did a in-
place upgrade of Windows XP Professional; installed all
the new drivers associated with the motherboard. and
applied Windows XP SP2 and all patches.
Everything looking good. However, the new system would
freeze, sometimes 5 minutes; or 2 hours. Sometimes even
before the login page appeared.
I have changed the CPU and memory and it still freezes.
However, the system will not freeze if I disabled
the "HyperThreading" feature in the BIOS.
I called Intel support; they suggested me to try to
install a new copy of the Windows XP and to verify if it
still freezes. With a clean installation, the system
did not freeze
Intel support said when upgrading from a non-
hyperthreading motherboard to a hyperthreading one;
Microsoft Windows Setup did not replace all the drivers
properly.
I would really like to use my original Windows instances
with the HyperThreading enabled.
Any suggestions is appreciated.
Thank you
David
You can try doing another repair operation. You can use the File and
Settings Transfer Wizard if you want just your settings and documents.
This would require a clean install and then load these settings/files
back on (it will not keep your installed applications, just their
settings). If you need help with either of those, let me know.
Here is what I would do though. First, back up all of the data on the
computer, then I would make a clean install of XP (it may require
activation over the phone since things have changed, but that shouldn't
be a problem unless by chance the original was an OEM install which
could be causing the problem by itself). I would then load all of my
applications and data back on and image the drive/fully back it up once
I got it to a point I thought was perfect.
Nathan McNulty
David Chan wrote:
> Hello,
> Pentium 4 3.0G CPU.
> did not freeze
> properly.
> Thank you
> David
Nathan,
This is what I have done in the separate disk; but there are so many
applications, that I need to re-install which I hate.
I hope there can be a better way. I have been using the same system
upgrading from Win2k prof which was installed over 4 years ago.
Thanks for your help
David
> Nathan McNulty
> David Chan wrote:
> > Hello,
> > Pentium 4 3.0G CPU.
> > did not freeze
> > properly.
> > Thank you
> > David
