Question System Freezes Momentarily and Makes Buzzing Sounds When In Games
dpeel
167
6
18,695
I have the following hardware configuration:
Asus Prime X-470-Pro Motherboard
AMD Ryzen 5-5600X CPU
AMD Radeon RX 6700XT 12 GB VRAM
16 GB DDR4 3200 RAM
Windows 10 Pro fully up to date
Latest AMD Video Drivers
The problem I'm having is when starting and trying to play newer video games....Stalker 2 an d Kingdom Come Deliverance 2, the game freezes momentarily and makes a buzzing sound through my speakers. I only have been experiencing this with newer games and don't have this problem outside of games when using other programs or browsing the Web. If I had to guess, I'd say the problem is with my video card.
I would appreciate help trying to figure out what is causing this.
My power supply is probably 6 to 7 years old. I've upgraded this system with a new cpu from 2600X to the 5600X and changed out the video card from RX580 8GB card to the RX 6700XT 12 GB card in June 2023.
So you think my power supply might be the problem and not the video card. Since I have had no problems with other programs and browsing, I didn't think the video card was the problem but wasn't sure.
Yes, this very well could be a PSU issue, as prevously noted.
What is the make/model of yours? The info is on a label on the side of the device.
At this point I think I'm going to order a new power supply and install it. I built this system 6 to 7 years ago so regardless of what I've had, it probably could be the problem. I'll order a new power supply today, install it, and then see if that fixes the problem and report it back to you. Thank you for your input.
I just installed a new power supply and I'm still having a problem with momentary freezing and buzzing sound coming through my speakers so the power supply doesn't seem to be the problem
Let us know how it goes after installing. Make sure you don't reuse ANY power cables used with your current PSU.
Good Morning,
I wound up buying MSI 850 Watt Power Supply and installed it last night. After installing I started Kingdom Come Deliverance 2 and had the same problem with it Momentarily Freezing and a buzzing coming out of my speakers. I then thought the problem had to be related to a problem with my MSI RX 6700XT video card but since I didn't seem to have problems with other games or programs, started wondering if it was caused by a video software setting. I started up my AMD Adrenain software Suite and changed the game setting from Performance mode to Default mode. That seems so far to have fixed the problem and I'm not sure why.
