Question System Freezing - ESENT 533, 508, 510
OrtegaSeason
7
Hi there,
Last night the programmes on my PC all froze a couple of times. Each time it lasted for about 3 minutes, then they started working again. The first time it was when I was trying to open a web page. The second time it happened when I pressed the home button. When I checked Event Viewer it gave the following readings under ESENT 533, 508 and 510;
taskhostw (5560,D,0) WebCacheLocal: A request to write to the file "C:\Users\Decipher\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.jfm" at offset 8192 (0x0000000000002000) for 8192 (0x00002000) bytes has not completed for 36 second(s). This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
taskhostw (5560,D,0) WebCacheLocal: A request to write to the file "C:\Users\Decipher\AppData\Local\Microsoft\Windows\WebCache\V01.log" at offset 110592 (0x000000000001b000) for 20480 (0x00005000) bytes succeeded, but took an abnormally long time (36 seconds) to be serviced by the OS. This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
taskhostw (5560,D,0) WebCacheLocal: A request to write to the file "C:\Users\Decipher\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.jfm" at offset 8192 (0x0000000000002000) for 8192 (0x00002000) bytes succeeded, but took an abnormally long time (36 seconds) to be serviced by the OS. In addition, 0 other I/O requests to this file have also taken an abnormally long time to be serviced since the last message regarding this problem was posted 9222 seconds ago. This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
I've already run Check Disk and Windows Memory Diagnostic and they reported no problems.
Are there any further tests I can carry out to identify what has caused this and how to prevent it? Thanks for any help.
These are my system details by the way;
Operating System: Windows 10 Home 64-bit
CPU: AMD A12 Bristol Ridge 28nm Technology
RAM: 8.00GB Single-Channel Unknown @ 1064MHz (15-15-15-35)
Motherboard: HP 81B8 (P0)
Graphics: HP ALL-in-One (1920x1080@60Hz) 512MB ATI AMD Radeon R7 Graphics (HP)
Storage: 1863GB Western Digital WDC WD20EZRZ-60Z5HB0 (SATA )
Optical Drives: hp HLDS DVDRW GUD1N
Audio: Realtek High Definition Audio
Hello
Can you please check if any updated version of your default web browser is available?
Also, please check if any Windows updates are available.
If this doesn't help, please check for graphics driver updates.
Since CHKDSK and Windows Memory Diagnostic didn't come up with any errors, and after trying the solutions given above, if the issue still persists, please try Running the SFC /SCANNOW Command and see if it does the trick.
Please report back with the results for any further assistance.
Cheers!!
Hello
Cheers!!
Thank you for the response. I followed your instructions and ran the SFC / SCANNOW. It came back as “Windows Resource Protection did not find any integrity violations.”
