System Hangups
Bob
3,414
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Have XP installed on a Toshiba Satellite laptop. When I
login, the system hangs and slowly processes the login
procedure.
Initially I thought it was a mouse problem because the
mouse wouldn't work on either USB port or PS2 port. Then
it started to work on one USB port. After playing around
the BIOS, all ports now work. But after doing a restart,
neither the keyboard nor the mouse works. Have to power
off/on the laptop to get it working.
Any assistance would be greatly appreciated.
Thanks
Recommend you go to Toshiba Help line or give their support number a
call. Make sure you have the model number of your laptop handy when
calling.
Bquinn
"Bob" <anonymous@discussions.microsoft.com> wrote in message
news:0b1a01c46e87$13684f60$a401280a@phx.gbl...
> procedure.
> Thanks
Thanks
>-----Original Message-----
support number a
handy when
>calling.
>Bquinn
message
>> procedure.
Then
around
restart,
>> Thanks
That and check and make sure that you have all of the drivers and stuff
up to date for your computer. Check Toshiba's website and look under the
support section. Find your laptop and see if there are any available
updates, patches, fixes, BIOS updates, etc.
Nathan McNulty
Bob wrote:
> Thanks
> support number a
> handy when
>>calling.
>>Bquinn
> message
>>>procedure.
> Then
> around
> restart,
>>>Thanks
Downloaded all the updates from Toshiba's website. Also
called Toshiba tech support. 2 problems. The laptop is
an older model and since it came with Win2K pre-installed,
they won't support any XP related issues. I have to
contact Microsoft. Will copying an image from a different
laptop work?
drivers and stuff
look under the
any available
>Nathan McNulty
>Bob wrote:
>> Thanks
>> support number a
laptop
>> handy when
>>>calling.
>>>Bquinn
>> message
I
>>>>procedure.
>> Then
>> around
>> restart,
power
>>>>Thanks
