system info msinfo32
Laurie
37
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
when i click on system information either in program files system tools or
try to run msinfo32.exe instead of system info coming up i get the help and
support page. already tried the fix from kelly's site. didn't help. i am
running xp sp1.
You may or may not be able to fix this. I can't fix mine.
It used to work but a Windows Critical Update screwed it up.
I don't know which CU is the culprit. Doesn't matter, it's screwed up.
This works. It's what I use.
Go here:
http://www.kellys-korner-xp.com/xp_tweaks.htm
Read instructions at the top.
Scroll down to and Click on:
172. Msinfo32 Batch File - To Gain Access
Unzip and save it where ever | Create a shortcut | Place the shortcut in
your Start Menu, Desktop or where ever | Click the shortcut to open msinfo32
Saves typing it in the Start | Run box every time.
Also in case any of this may work for you.....
Go here:
http://www.kellys-korner-xp.com/xp_m.htm
Scroll down to:
Can't Open Msinfo32
Read the info.
Hope this helps. Let us know.
Wes
In news:E85A724B-D277-47D6-AA0B-A733CFD83DFA@microsoft.com,
laurie <laurie@discussions.microsoft.com> hunted and pecked:
> tools or try to run msinfo32.exe instead of system info coming up i
> get the help and support page. already tried the fix from kelly's
> site. didn't help. i am running xp sp1.
