I'm running a nzxt case m59. i installed a second hard drive and got a 5c temperature drop. i just moved it off the carpet onto a particle board desk and it dropped another 5c. It has a fan filter on the bottom but the psu covers it with no air between it. no other holes on the bottom. is that normal for the temp to drop from moving off carpet? does the case gather heat on the bottom and transfer to the carpet? im sitting at 20c cpu temp at idle right now. I'm just using 5 fans, no water cooling. im thinking about adding a fan to the chipset and ram. could it be possible to drop the temp another 5 to 10 degrees with that?
