System only boots from USB, not Optical or HDD
pefrase
4
I installed a new CPU cooler because the old one broke. After doing so I have a very strange problem: my system will not boot from the hard disk or the DVD drive, only from a USB stick. POST is fine, and the BIOS splash comes up, and the drives are detected, but then it just says "Boot error" on a black screen and hangs there. After booting from a USB image, I confirmed that the drives are detected and operational, as I was able to mount all of them from the Linux live disk on the USB.
So far, I have tried the following:
- Disconnecting the optical drive and booting only from the hard disk
- Disconnecting the hard disks and booting just from the DVD--this produces a message telling me to insert a bootable disk, even though I have inserted a disk that boots fine on another machine
- Reinstalling the BIOS
- Resetting the CMOS using the on-board jumper
- Taking out all but one stick of memory
- Disconnecting and reconnecting all the connections to the motherboard.
Nothing works! It seems like it has to be something with the motherboard --an Asrock A770DE+, if that matters--but I'm at my wits end about what more I can do.
I've tried switching around the SATA ports for the hard drives (there are four in the system), and I confirmed that the correct drive was listed as the boot device. This still gives the "Boot error" message--whereas if I attempt to boot from one of the non-boot drives, I just get a black screen and a blinking cursor, with no message.
Arch Linux, with the boot partition on an OCZ Vertex SSD drive. And "Boot error" is literally the entirety of the error message. Or, to be a bit more exact, if I disable the splash screen on the BIOS, I see a few lines reporting that all four hard disks have been recognized, and then there is a black screen with a couple of blank lines and then "Boot error", with a blinking cursor below it. If I hit enter, the cursor will go one line lower, but the system doesn't respond to any other commands except ctrl-alt-delete.
