Started my first pc build and have been troubleshooting all day. GPU, CPU, cooler, ssd, ram and psu are the only things installed. I sometimes get bios to display but once I power off its gone again and randomly reappears. I have replaced the motherboard with a new one and the ram, same issue still occurring. Everything seems to power on and fans running but nothing displaying bios.
Here is what I've done so far:
Specs:
3060ti
Ryzen 7 3700x
MSI B550 a pro
16gb (x2) corsair
- update bios with USB and flash button
- tried older versions of bios
- remove CMOS battery
- reseat components many times
- checked cpu pins
- when I was able to access bios all the components were listed
- All led indicators tell me the cpu, ram, and gpu is there
- monitor works + cables
- tested psu on its own with jumper
- cpu alone, powers on
- Been plugging the monitor into the hdmi slot on the gpu
- Do I need an old cpu in order to update the motherboard to accept the new cpu I have?
- boot led is on which indicates the booting device is not detected or fail
- when USB bios update is plugged in led turns off. When USB is removed led stays on. Wondering if the updates hasn't been staying on the motherboard and if its been reading the flash drive. Friend mentioned that flash drive might have issues since I'm downloading it from a mac.
Specs:
3060ti
Ryzen 7 3700x
MSI B550 a pro
16gb (x2) corsair
