System Restore with GTX 660
jjkiii
I would like to know if there are any precautions i should take while resetting with my GTX 660. Would i have to reinstall the drivers after i restore my windows 7 computer back to factory settings again?
If the restore point was made once the drivers got installed 'normally they are' then you wouldn't need to. Your drivers will no longer be up to date, but as long as you have Geforce experience installed it will catch you up on all of the drivers. So the restore point will only remove any changes to drivers and files made from the point it was created.
