According to its User manual, your psu tester says absolutely nothing about how the psu responds to, or whether it can support a given load.
If you take out the memory - system will turn on and stay running but continuosly beeps, still no video, no post. I also tried a smaller amount of some known good memory and it reverted to shutting down as before. Also there is nothing connected to the PS just the MB.
I have faced this issue some days before,
my friend give me a solution then my system works good right now,
Sometimes processor got heat up then system will be shut down automatically without any beep or sound due to "Silicon Paste" it will apply on processor and heatsink.
So the solution is that you should go to the market with your heatsink and processor and apply silicon paste on your processor and heatsink.
After applying "Silicon Paste" fit the processor and heat sink into mobo and check again. your system gives better speed before.
Thanks for the replys but hate to say nothing working yet. I think the MB caught an e-spike and messed up something on the MB that's not financialy repairable other than a new MB.
Sorry, I failed to mention that I bought 2 Thermaltake PSU ( 1 for main sys & 1 for GP). I tried it out on this other machine and to no avail. Sooooooooooo? Thanks again.
