Hello yall,
So I usualy preface this that I have this build for not exactly longest of times, but its been in use for some time. I used to always build something that would last for some time and while this aint the top of the crop PC, I would say for 1080p gaming it suffices realy well.
For some specific reason the system lags quite often, well, more like the longer it runs the more it stutters. Little things, like playing WoW (yes, very CPU perf heavy game) I get very short, like not even a full second stutters, more like half a sec or less every 30 secs to 1 minute. While recently playing Dead Space remake and its fullest settings the issue was identical and it also occured during Warzone gameplay aproximately a year ago. The overall performance of the rig is horrendous as of late, not being able to tab in and out of applications quick, making them effectively not responding. When powering down the system it 1. lags extremely during power down (the spinning circle during power down just stutters extremely. 2. It takes ages to power down the rig itself even though the system and peripherals are long powered down.
I might have another issue of note, but it might be a little detour: Up until recently I my CPU was in okay numbers temp wise and performance wise. I use Coolermaster MASTERAIR MA610P ARGB cooler for my CPU and I cant specificaly remember the instalation guide and I cant tell how it was connected. Aprox 1 year ago the RGB stopped working and I paid it no attention, however recently I also found out that the back cooler is not spinning, so I connected it to the motherboard to temp_CPU slot i think ( as I said, I am not sure if this was even connected there at all or if it should use only one 4-pin header) and it spins quite loudly. I cant see it in bios so I cant ascertain the RPM, but the rig runs considerably more loud now.
TLDR: Whole rig lags the longer I use it. CPU temps are OK, system is on M.2, Games in question are usualy on that M.2 and are not hindered by hardware limitations (GPU util is not high, CPU neither aside 2023 releases). CPU temps are between 50- 60 degrees. Please assist with diagnostics so I can ascertain which component is at fault.
SYSTEMS INFO:
CPU: i7-8700
GPU: MSI Supreme RTX 3070
MOBO: ROG STRIX Z370-F GAMING (BIOS last updated at the beginning of 2021)
RAM: HYPERX 16GB 3200Mhz (cant find the specific kit, but its two 8 gig sticks)
PSU: 650W EVGA G2 Supernova
Storage: Samsung 980 PRO 500GB M.2, WDC WD10EZEX 1TB 7200RPM and WDC WD40EZRZ 4TB 5200RPM (system is on the M.2 with all the games that prerformance wise rely on SSDs, rest is for movies and old games)
Case: Coolermaster Mastercase H-500M
Display: Main display in use: Acer KG271
Windows version: Windows 10 ver. 10.0.19045 Build 19045
Im pretty sure I missed out on alot of deets yall need, feel free to hit me up. This is getting progressively more and more unbearable as the performance degrades over time and I have no idea why.
Cheers.
SYSTEMS INFO:
CPU: i7-8700
Cheers.
