hi all i am running a 8800gts 640mb oc, amd 64 x2 5000+ and a low end motherboard x8 pci-e.
the problem is i want to upgrade some components in my pc to
ASUS m4a79xtd-evo running 16x pci-e
Phenom 955 3.2ghz quad
ddr3 1600mhz
i am running my original system with a gigabyte 460w power supply and runs it fine, but i wanted to know if this power supply would run the new components, the psu is just over a year old but had no problems with it as yet or would you get a new psu to run the new components.
going on to a psu calculator my original system is using 296w and the new system will be using 344w, dont know how accurate the psu calculators are.
any opinions will be great.
thanks
ddr3 1600mhz
thanks
