Question System upgrade ?
csaba0927
18
Hey guys!
My poor little r7 2700x has started to show its age in some titles, and I thought it's time to do an upgrade. I'm planning to buy a ryzen 7 5700x and it'd be paired with a b450 tomahawk max II, Be Quiet! pure power 11 600w psu and a RX6600xt with 32gb ram.
Will I be bottlenecking the cpu in 1080p 144hz?
If so, should I upgrade to a 6700xt?
If I need to upgrade, will my current psu would be able to power the system?
Thanks for reading, and for the replies! 🙏
You will see a minimal upgrade, if you must, jump to the 7800XT instead.
with 32gb ram
Make and model of your ram?
How old is your PSU?
If you plan to upgrade the CPU, make sure you're on the latest BIOS version.
Kingston fury beast ddr4 32gb 3200mhz (4x8gb).
Approx. a year old.
Sadly that's far out from my budget, I'm willing to spend around 100k HUF without including the gpu (which roughly equals to 250€, 270$)
How about a 7700xt instead?
