system uptime
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Any recommendations for a utility that will give system uptime?
I use NEWT Freeware which works great over a network and gives other info
too, but something simpler is needed by a colleague. I can't recall what I
used before the NEWT sw, but it did just give uptime.
(I think Norton Utilities has something too, but he doesn't have that).
tia
Hi Alan,
Check out this utility created by Doug Knox MS-MVP.
System Uptime Utility
http://www.dougknox.com/xp/utils/xp_uptime.htm
Regards,
Bert Kinney MS-MVP Shell/User
http://dts-l.org/
> uptime?
> gives other info too, but something simpler is needed by
> a colleague. I can't recall what I used before the NEWT
> sw, but it did just give uptime. (I think Norton
> tia
If XP Pro, doen't work with HOme...
Start | Run | Type: cmd | OK |
At the command prompt type:
systeminfo
Hit Enter.
When Windows has gathered the data, the System Uptime can be found near the
top of the report.
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:d7vgqu$dk9$2@newsg3.svr.pol.co.uk,
Alan Smith <alan@hidden.email> hunted and pecked:
> tia
