system won't boot after adding a harddisk
Oct 10, 2018
Hi together,
maybe somebody here have had the same problem and can give some hints.
Yesterday I added a HD to my self-built system. The HD was used in an external case. After that the system wont boot any more. No leds, fans dont turn, absolutely nothing. First I thought it was the PSU. I have another one at home but the switching the PSU didn't help. Now I think there are only two possibilities: either the Mobo or the case (power switch). Mobo is MSI X470 Gaming Plus, case is Sharkoon BW-9000V, both are only weeks old.
Some system information:
Mobo: MSI X470 Gaming Plus
CPU: Ryzen 71700
RAM: 2x 8GB Ballistix Sport LT 2400
Graphics: Gigabyte NVidia 1070
PSU: Corsair RM850
Everything worked fine just before adding the HD.
Grateful for any idea.
@Tolis_GR thanks for the reply. I replaced the power switch with a jumper and turned on the PSU. Nothing. A fan which is directly connected to the PSU started turning for one or two seconds and then stopped. No leds blinked.
What now? Can the CPU be the reason (though I didn't touch it at all, nor the CPU fan)? The PSU can be excluded as the cause, tried two different ones, both worked fine in another system.
