I tried to build a new system:
New Components:
-Asus P5N-E SLI Socket 775 Motherboard
-Intel Quad Core Kentsfield 2.4Ghz Q6600 CPU
-OCZ Platinum Rev 2 2048MB PC6400 DDR2 800MHz x2
-BFG Tech 650W PSU
-Thermaltake V1 CPU Cooler for AMD and Intel CPU
Old Components:
- BFG GeForce 7900 GT/GTO 256MB
Here is my problem (please bare with me, English is my second language):
After installing all the components into the case I tried to power up the system but it would not power up (CPU fan came on for a split second though) but the LED on the mobo would always be lit.
I took everything apart again and checked the CPU and mobo for any damage but could not find any, reinstalled everything (making sure that the thermal paste between CPU and heat sink was correctly applied) nothing had changed. First I thought it might be due to faulty RAM and took out all but 1 stick then switched between the 4 sticks I have and changed the slots it was in, no change.
Now when I take out my video card completely the system seems to boot up fine, except for the 1 long 2 short beeps that, if I remember correctly, mean there is a problem with the video card.
I searched many different help boards for a solution to this problem but couldn't even find anybody with the same issue. Having looked at many different sites I was under the impression that tomshardware.com has a very competent community and I ask your advice.
Thank you very much!
EDIT: The Video Card is working fine in my old system.
New Components:
-BFG Tech 650W PSU
Old Components:
