E Esteban Barajas Reputable Feb 5, 2015 30 0 4,530 Feb 20, 2015 #1 Ok, so i have everything set up wired up i've triple checked control panel connections motherboard lights up aswell as the graphics card but my case power button when i click wont turn on the system.. i'm puzzled any help?
Elemential Reputable Jan 24, 2015 820 0 5,360 Feb 20, 2015 #2 I recommend you open your PC and re-connect all the leads from the PSU Upvote 0 Downvote
B boosted1g Titan Jun 12, 2013 14,847 9 81,765 Feb 20, 2015 #3 This writeup covers 90% of all problems: http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems Most common issue is that the user did not hookup the cpu power wire, other most common is poorly seated ram or gpu. If you have fully went through this tutorial and still having issues then you likely have a defective part and we can help you troubleshoot. Upvote 0 Downvote
E Esteban Barajas Reputable Feb 5, 2015 30 0 4,530 Feb 20, 2015 #4 ok so the 24 pin on the mb was loose, the problem now is that my screen is getting "no signal" Upvote 0 Downvote
