t2p4 power issue - help
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a p55/t2p4 board that fails to power up. I replaced the power
supply with a brand new power supply (same model) but the cpu fan
spins for 1/2 second when I apply power, then stops. Computer was
working fine last week, but exhibits this problem now. Any ideas
what's wrong or what to look for? Is the board toast?
Thanks!
No expert by a longshot, just tossing out some ideas.......
Does the power supply's own fan keep spinning?
(A board shorted to ground should turn the PS off, or blow the fuse)
How about when it's not plugged into the board?
(Lack of "load" from the board can also turn it off)
How's the power switch? Did the new PS come with a new switch?
Does the PS work with other boards (if you have any to test with)?
What kind of voltage do you get between black/yellow and black/red
on any of the power cables when the PS is turned on? How about when
Have you tried slicing the board apart layer by layer and following the traces?
No, forget that one.... takes too long and makes a big mess. :)
Thanks for your ideas. Comments below. Any other thoughts?
On Thu, 02 Sep 2004 11:35:11 GMT, "MasterBlaster"
No. The old PS fan and the new PS do not come on at all connected to
the MB with or without a drive attached.
Yes, new PS came with a switch. Old PS switch was ok also.
Unfortunately not. All my other boards are ATX.
Old PS tested without load and the voltages were fine. I had it tested
by our hardware experts at work.
Hehe, nope. Sounds like a good excuse to get another mainboard!
