How do I get it so AIM isnt showing on the task bar 24/7 when its running when I hit esc to minimize it to the system tray it still shows on the task bar, which i dont want, I want it to be like in windows XP.
I think if you right click on the icon you can remove it from the taskbar and change the options, if not , right click on the taskbar and the option should be in there
