ermitanas Commendable Mar 29, 2016 48 0 1,530 Jul 12, 2017 #1 It is written on scan.co.uk that the TDP of AORUS Radeon™ RX580 8G is 135 W. Is that correct? Other RX 580 cards have 185 W TDP. Can't find more info anywhere. link
Solution Dark Lord of Tech Jul 14, 2017 TDP: ....Like stated above ....Your card is 185w TDP and that is usually the standard with 580's, some OC models do go up to 225 like my LE.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jul 12, 2017 #2 My Sapphire 580 8GB LE has a 225W TDP. Upvote 0 Downvote
K kaptainkuftic Honorable Jul 26, 2016 1,430 1 11,965 Jul 12, 2017 #3 "With a 185 watt TDP, the Radeon RX 580 only needs power from one 8-pin connector. Aorus has chosen to go with an 8-pin and 6-pin connectors design instead to ensure maximum power delivery." - https://proclockers.com/reviews/video-cards/gigabyte-aorus-radeon-rx-580-xtr-8g-video-card-review/page/0/3 I'd probably play it safe and count on the 185 TDP Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jul 12, 2017 #4 My Sapphire 580 8GB LE has a 225W TDP. https://videocardz.net/gigabyte-radeon-rx-580-8gb-aorus-xtr/ 185W for this one ^ Upvote 0 Downvote
ermitanas Commendable Mar 29, 2016 48 0 1,530 Jul 13, 2017 #5 kaptainkuftic : "With a 185 watt TDP, the Radeon RX 580 only needs power from one 8-pin connector. Aorus has chosen to go with an 8-pin and 6-pin connectors design instead to ensure maximum power delivery." - https://proclockers.com/reviews/video-cards/gigabyte-aorus-radeon-rx-580-xtr-8g-video-card-review/page/0/3 I'd probably play it safe and count on the 185 TDP This is for extreme edition.This is not my card Upvote 0 Downvote
BurgerandChips66 Honorable Jan 11, 2016 688 3 11,365 Jul 13, 2017 #6 Is this your card? https://videocardz.net/gigabyte-radeon-rx-580-8gb-aorus2 In which case the TDP/TBP is listed as >185W. I haven't heard of any RX 580's with a 135W TDP. The RX 480 was 150W (or more). The 580's tend to sip a bit more power due to higher core clock and voltage. Upvote 0 Downvote
ermitanas Commendable Mar 29, 2016 48 0 1,530 Jul 13, 2017 #7 BurgerandChips66 : Is this your card? https://videocardz.net/gigabyte-radeon-rx-580-8gb-aorus2 In which case the TDP/TBP is listed as >185W. I haven't heard of any RX 580's with a 135W TDP. The RX 480 was 150W (or more). The 580's tend to sip a bit more power due to higher core clock and voltage. yes, it is. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jul 14, 2017 Solution #8 TDP: ....Like stated above ....Your card is 185w TDP and that is usually the standard with 580's, some OC models do go up to 225 like my LE. Upvote 0 Downvote Solution
