Tech Help: Bally Sente Night Stocker
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I just picked up a Bally Sente Night Stocker yesturday. I was told the
the monitor did not work but the boardset worked be cause they could
hear noise from the speakers.
Anyway the monitor seems to work as I can turn the brightness up and
see the tube glow with slight diagnal lines.
The boardset has an LED light that lights up and I checked the power
board and it's putting 5vdc out. Is there anything I can check or
maybe something that is prone to go on the Sente board?
Thanks,
Don
NJ
Could be one of ther Boards. Ebay usually has the boards cheap Ie
Mainm Board, Power Board, SOund Board and the Game PCB. You should be
able to get another game PCB any Bally-Sente game to see if it will
work. Of course you can't play the game as Night Stocker is Driving.
Does anyone have a Bally Sente game working in central NJ that I could
try my boards out on to see what is and what is not working?
Thanks,
Don
I have a complete working Stocker boardset pulled from a damaged
cabinet. The 4 boards in the pictures. not the mounting plate or
transformer. $75 shipped in the USA.
(Note: this is Stocker not Night Stocker)
DGoooch@aol.com
>Thanks,
>Don
Dan in Denver
Click here for my current auctions
http://tinyurl.com/68o72
www.classicarcaderesource.com
OOps. here are the pictures.
http://www.members.aol.com/dgoooch/StockerPCB1.JPG
http://www.members.aol.com/dgoooch/StockerPCB2.JPG
>DGoooch@aol.com
>>Thanks,
>>Don
>Dan in Denver
Dan in Denver
Thanks for the offer Dan but, I'm not sure the whole game working is
worth that much..
Don
Usually on ebay the stuff will get no bids at 9.99 for the compleye
boards. If it has wire Harness/CP it will go for a little more. If
you want to just sent me the small PCB I can test that for you.
Thanks Steven
Thanks Steven
