TECH: INTREPID background problem
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hello, I've an INTREPID board. You know that it is very similar to "THE
PIT".
This is the problem:
the right part of the background is repeated both in the right side and
in the left side. Spites and sound ok.
In other worlds the background is divided exactly in two parts
vertically and in each part you can see the same picture.
Any idea?
Thanks,
vernimark
anyway, if you know where to download schematics of
intrepid and/or the pit and/or portman....
many many thanks...
vernimark@vernimark.com wrote:
: Hello, I've an INTREPID board. You know that it is very similar to "THE
: PIT".
: This is the problem:
: the right part of the background is repeated both in the right side and
: in the left side. Spites and sound ok.
: In other worlds the background is divided exactly in two parts
: vertically and in each part you can see the same picture.
: Any idea?
: Thanks,
IIRC, the background circuitry is in that block on top of the pcb.
If yours is epoxied, you're pretty much screwed.
Mark Spaeth mspaeth@mtl.mit.edu
50 Vassar St., #38.265 mspaeth@mit.edu
Cambridge, MA 02139
(617) 452-2354 http://rgvac.978.org/~mspaeth
I have two blocks: one epoxied and one not. The problem is shown in
both cases (I tested them with a "THE PIT" pcb and they work).
Is it possible to find schematics?
Marco
