TECH: Mat Mania sound problems
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
All,
I have a Mat Mania board that has sound issues. You can only hear the
"One....two....three!!!!" very faintly. There are no other sounds
present. I **think** this has been caused by the board being plugged
into its harness upside down which perhaps sent some power to a very
inappropriate place on the board. Since I don't have the schematics for
the board and can't find them anywhere, can anyone suggest a place to
start?
And before anyone suggests it, I already know that acquiring a new
board would probably be much easier than trying to fix this one.
Thanks.
Corey
G
Guest
Guest
Ahhh Mat Mania. My first game. I would start by trying to locate the
audio amp. Unfortunately my PCB is in storage so I can't help you you
but look for linear IC's near the audtio circuitry. If need you you
could start at the edge connector and work your way back.
Good luck...
-Adam
www.onecircuit.com
