TECH WGK7901 to WGK7601 Swap gone weird
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hey all..
I had a joust which had a bad monitor. The original was a WG19K7901.
I had a spare 19K7601 laying around and put this into the Joust cab. I
also did a cap kit on this monitor. Now I can't get the picture to
stabilize..It rools Vertically...Adjusting the VHOLD slows it don but
it never fully stops .Is there a sync difference in these two
monitors?
On the old monitor it was wired like this
> Purple/Red
> Purple/Green
> Purple/Blue
> Black
> Purple/White
> Solid Purple
All on one connector...when I hooked the 7601 up to this connector I
got a lot of roll...so i figured the sync must be different...I stole
the connector that went with the 7601 and hooked it up as shown..
>Purple/Red
>Purple/Green
>Purple/Blue
The rest were Blank
Then on the seperate three pin connector I hooked..
>Purple White
>BLANK
>SOLID PURPLE
Is this right or did I mix something up? I really wanna play Joust but
it is difficult hen the picture is rolling...
Thanks in advance
Josh
you have no ground wire
the black one
but i believe you have the sync wire not hooked up right.
dosent seem right to have a blank in the middle, usually blank is first
then -Vert, and last -Hort.
I was under the impression that all 7000 series chassis were
interchangable , no muss no fuss . I am in the process of building up
a cab and was planning on doing something similar . Any thoughts on
this ?
joshers17@hotmail.com wrote:
> Hey all..
I
> monitors?
> > Purple/Red
> > Purple/Green
> > Purple/Blue
> > Black
> > Purple/White
> > Solid Purple
> >Purple/Red
> >Purple/Green
> >Purple/Blue
> The rest were Blank
> >Purple White
> >BLANK
> >SOLID PURPLE
but
> Thanks in advance
> Josh
You need to apply ground to either pin 4 of the 6 pin connector or pin 1 of
the 3 pin connector.
<docfrankie@hotmail.com> wrote in message
news:1115401515.814481.199290@g14g2000cwa.googlegroups.com...
> the black one
The is also a trace on the cpu board to cut to change the sync from neg to
pos of pos to neg. I believe this has to be done when you change the
monitor.
> the black one
There is an excellent William's game site online but I'm on someone elses
computer and I don't have the link for it. The site tells you everything you
need to know about William's games. There is a lettle tidbit of info there
about the trace cut. Once you cut the trace your picture will sync perfect.
"arcadegamer" <arcadegamer@wi.rr.com> wrote in message
news:1115419086.950044.22800@g14g2000cwa.googlegroups.com...
> this ?
> > Hey all..
> I
> > monitors?
> > > Purple/Red
> > > Purple/Green
> > > Purple/Blue
> > > Black
> > > Purple/White
> > > Solid Purple
> > >Purple/Red
> > >Purple/Green
> > >Purple/Blue
> > The rest were Blank
> > >Purple White
> > >BLANK
> > >SOLID PURPLE
> but
> > Thanks in advance
> > Josh
<joshers17@hotmail.com> wrote in message
news:1115391588.010690.60850@g14g2000cwa.googlegroups.com...
> Hey all..
> monitors?
>> Purple/Red
>> Purple/Green
>> Purple/Blue
>> Black
>> Purple/White
>> Solid Purple
>>Purple/Red
>>Purple/Green
>>Purple/Blue
> The rest were Blank
>>Purple White
>>BLANK
>>SOLID PURPLE
> Thanks in advance
> Josh
Try blank, purple/white, purple (on the separate 3 pin connector), and if
that doesn't work, leave the same connection and tie the 2 purples together.
Otherwise you will have to do the sync modification and the original 6 pin
configuration should work.
Joust is working I used the old connector ( the 6 pinner) and hooked it
up as it was original in the cabinent...adjusted the V hold and the H
hold and it works beautifully...I guess i should left the wiring alone
to begin with :)
Thanks for everyone's replies
Good going. Sync problems can be a pain in the ass when working in a cabinet
on an awkward angel with not a lot of space, trying to move the pins around
for the different combinations. It would be nice if there would be one
connection and a dip switch bank for the various syncs.
news:1116217558.598097.44460@f14g2000cwb.googlegroups.com...
> to begin with :)
