Temperature problems with Noctua NH-U14S cooler
Kuhanz
21
My temps are not what I supposed when I bought this cooler.
Idle temp according to AsRock extreme tuning utility: 38c (room temp 24c)
Idle temp according to RealTemp: Core1~33c, Core2~34c, Core3~30c and Core4~28c
When I start IntelBurntestV2 temps are:
aXtu: 77c
RealTemp: C1 ~70c, C2~75c, C3~72c and C4~68c
When I stop Intel Burntest temp drop instantly to idle temp
Current OC: 4200MHz, Vcore is around 1.24v-1.25v under load and ~1.1xxv at idle
Take a look at this picture
Red: Area without any contact
Blue: Processor under IHS
Could problem be that top part of cpu is not having good contact enough? I don't have pressure paper to make sure. I have tightened screws as much as I can without breaking board
Your temperatures are actually fine. In the 70s is a good load temp for a Haswell i5.
Your conclusion about contact is flawed. The thermal paste gets pulled between the CPU IHS and heatsink when you remove it. Removing it can create air bubbles when contact is broken, even if there were none when it was installed.
- Clean the CPU and heatsink
- Apply a 1/4" or 1cm line of thermal paste along your CPU core
- Mount the heatsink and tighten it down evenly
- Enjoy, your temps are fine
As I sad, try lowering the voltage and test the stability of the system, here is an example tested:
4.2Ghz - No increase in core voltage (might even decrease it!) - Default load voltage is around 1.18v
4.3Ghz - 0.003v increase
4.4Ghz - 0.06v increase
4.5Ghz - 0.11v increase
4.6Ghz - 0.17v increase, but it was getting way too hot for confort ( over 85deg celsius)
Okay, i have only offset mode for cpu voltage in bios.
What should I use to measure voltage? I got HWmonitor and there is CPU VCORE around 1.064V-1.2V and "VID" 1.076V-1.271V
Right now I'm at work and I don't remember what i used for home pc... Sorry, try to google it and check the best options for you cpu, I have 4770k so there are some differences. Hope I was of any help.
