Hello, I recently just built my first system and everything has been working great so far. But I have some concerns over the temperature sensors. I have read the guide on core 2 temp sensors but my sensors seem to be confusing me.
System:
Motherboard = Gigabyte EP43-UD3L
CPU = E7400
Stepping = R0
CPU Cooler= XIGMATEK HDT-S1283
Case = Antec 300 with stock fans on low
Ambient = ~17C
Frequency = 3.8 Ghz (400x9.5)
Vcore Load = 1.248 (by cpu-z)
Load = Prime95 - In-place Large FFTs
Tcase (Temp3 by Speedfan) = 22c Idle, 62c Load
Tjunction0 (Core0 by Speedfan) = 36c Idle, 42c Load
Tjunction1 (Core1 by Speedfan) = 41c Idle, 42c Load
Load = Prime95 - Small FFTs
Tcase (Temp3 by Speedfan) = 22c Idle, 50c Load
Tjunction0 (Core0 by Speedfan) = 36c Idle, 45c Load
Tjunction1 (Core1 by Speedfan) = 41c Idle, 45c Load
The core temperatures are really confusing me. I read that some core duo's stick at low temps but shouldn't they be ~5C higher than Tcase at full load? RealTemp reads the same core values as well.
From what I understood out of the temp guide you can calibrate them by adding an offset which is based off of Tcase. Doesn't really make sense to me to just add a value to them to make them read 5 higher then Tcase, when you can just look at Tcase only. But I think I am getting that part messed up.
Any help with this would be greatly appreciated, and is 62C too high for that one reading?
System:
CPU = E7400
Stepping = R0
Ambient = ~17C
