Hey Guys!!
I have recently completed by custom loop with Ryzen 3700X. I have done some stress testing on AIDA x64 Extreme
I'm, seeing wired momentarily spikes in temps in intervals of 3-4 mins. I know ryzen is quite bursty CPU in nature but still with custom loop this behavior is wonky, how much cooling it needs to settle.
For a test of about 10 mins you can see temps of 65 with momentary spikes in temps to 70-74'C for like 1-2 seconds after every 3-4 mins interval.
Shouldn't be hovering in b\w 64-66 or just flat 65'C ? [not considering the initial spike, i.e, counter reaction time by cooling setup to handle heat load]
I ran it multiple times to monitor the process manager and boost clocks . voltages but no programs seems to have appeared to add stress when spikes are there, similarly boost clock shows no erratic behavior when the spikes are there ?
So why?
Just for info my loop setup Info:
30mm x 360mm Copper Rad
d5 pump
210mm Res
Soft Tubes and Brass fittings
Also i have setup a fun android app for system monitoring: [Stock settings, PBO off, No Manual OC, that is just a lucky shot[4400Mhz]
So why?
- I might have used too much thermal paste ?
- May be Ethyl glycol i added [10%] might have not mixed well with DW and when comes in contact with CPU die/fins in the block it reduces heat transfer momentarily.
d5 pump
210mm Res
