G
Guest
Guest
Hello, this is kind of a long story but i'll try to make it as short as possible. First i'll list my parts.
msi gtx680 sc 2gb gaming temperature 48-60c no higher
i5 2400 @ 3.4ghz with enhanced turbo gaming temperature 50-58c no higher
msi z77a gd65 motherboard
8gb corsair vengeance ram
corsair tx850w psu
Well, a few months ago I noticed that my psu was making an annoying ticking sound that is similar to two marbles hitting each other softly. I decided that I will RMA the power supply later on but I still used the computer for another few weeks. During those few weeks, I experienced a BSOD caused by caused by driver nvlddmkm.sys while gaming. After the blue screen, I decided to reinstall my driver, but for some reason the Nvidia 3d vision files refused to delete and I think was probably caused by me deleting it using this new software that I downloaded, which probably deleted it improperly. After trying to use driver sweeper several times to delete these files, I decided to give up and just let the nvidia installation do a clean install. A week later, my computer goes nuts. I start to get artifacting and driver crashing. I will be RMAing my ram and PSU tomorrow morning, but now I don't know if I'll have to RMA the GPU too since the psu screwed it up or something. I am in a really scary situation here and I hope that you guys give me some advice on how to deal with this problem and figure out what the hell is going on exactly. Since i'll be RMAing the psu and ram tomorrow I don't even have time to re install the operating system, and even if I had time, it would still be a bad idea to still use the computer with a possibly failing PSU (something that I should've thought of months ago when I heard that noise coming out of the PSU) .Anyway, what should I do at this point, besides crying myself to sleep?
corsair tx850w psu
