Hello
sometimes when i turn my computer on, the case fan makes the noise like if it was an turbine, my friend told me that it is ok as there is no Software to control the fan and when OS is starting in my occasion Windows 10, it takes control of it and change the fan speed to the normal after a while, maybe because the heat after night play is still in the case and other components as it just have few hours of cooldown, playing games that really kills the GPU and CPU, but i let it go for i think 2Minutes but then i realised that nothing was changing, as if it wasnt the OS fault, i checked the cabling if everything is plagged and nothing is touching to Hardware, but everything which is necessary to make PC run is plagged and nothing is touching, i checked that it is the Case Fan i spin it by hand when PC is turned off and saw that sometimes is it moving Forward Backward when spinning, is it the natural thing that the fan is doing this, or thing that is attached to it has loss and have to be put in place? also i changed the Thermal Glue ( or whatever it is called, i just like calling this Thermal Glue as it is easy to remember, and keep CPU and temperature in place like glue
) and i clean the PC out of Dust and other things with Compressed Air, ( i think in American Eng this is spelled differently but i live in UK so i use UK eng so please try use UK eng as i can get confused ),
Thanks for help,suggestions and explanation, and dont be shy if i made mistakes, we all make mistakes and learn from them, i will not judge you from mistakes, more likely i made some mistake with the OS controlling fan.
