lookerup Distinguished May 25, 2011 1,296 0 19,360 Jun 29, 2016 #1 What is the difference between a wifi range extender and access point?
Solution lookerup Jun 29, 2016 so let's say i need wifi to go thru walls, would an access point be better? since the extender just extends wifi with the sacrifice for speed.
greens Splendid Jan 27, 2012 3,773 7 26,965 Jun 29, 2016 #2 lookerup : What is the difference between a wifi range extender and access point? A wifi range extender receives a wifi signal and rebroadcasts it. An access point receives a wired connection and broadcasts it wireless. Many units are capable of both. An access point is always better. Upvote 1 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,846 22,155 184,590 Jun 29, 2016 #3 Router->Cat5e->Access Point->WiFi devices Router->WiFi->Range Extender->WiFi devices A range extender is just that. Extends the range. At the expense of actual performance. It has to talk in both directions at once. An Access Point is just to provide WiFi elsewhere, supplied by an ethernet cable. Upvote 0 Downvote
lookerup Distinguished May 25, 2011 1,296 0 19,360 Jun 29, 2016 Solution #4 so let's say i need wifi to go thru walls, would an access point be better? since the extender just extends wifi with the sacrifice for speed. Upvote 0 Downvote Solution
USAFRet Titan Moderator Mar 16, 2013 179,846 22,155 184,590 Jun 29, 2016 #5 lookerup : so let's say i need wifi to go thru walls, would an access point be better? since the extender just extends wifi with the sacrifice for speed. Router over there, WiFi waned over here. A Cat5e cable to from 'over there' to 'over here', and then an Access Point device to provide WiFi Upvote 0 Downvote
