[SOLVED] "The DVI-D port does not support D-Sub connection by adapter."
Dec 1, 2018
Hello everyone,
I am trying to upgrade my PC by upgrading Graphics Card ..
currently I am using GT 710 DDR3 2gb which has a VGA port ..
my monitor has a VGA PORT only
I am thinking about to buy a GTX 1050 Ti which doesn't has a VGA port
and from the website of the motherboard manufacturer I came to know that " The DVI-D port does not support D-Sub connection by adapter."
1050 Ti doesnt has a VGA port and only has the DVI-D port
what Should i Do now?
MB : GYGABYTE B150m-D3H DDR3
The motherboard specs won’t matter because you’re using the GPU. Some 1050ti’s have DVI and some don’t. But you can buy adapters for HDMI or DVI to VGA.
gofanco Pro-Series DVI-D to VGA Active Converter - with 3 Feet Micro USB Power Cable for Better Compatibility and up to 1920x1200@60Hz Black Male to Female (DVIDVGA) https://www.amazon.com/dp/B00RWFT8NG/ref=cm_sw_r_cp_api_i_cd3aCb8JJ2Z5H
If the 1050ti you’re looking at does have a DVI output this powered adapter will work.
