The phantom 410(case) has 2 USB 3.0 plugs. Do I need to get a Mobo with 2 US 3.0 plugs to be able to use them?
HeroponLuigi
109
Pretty much what the title says. I'm gonna try to build a pc but I have extremely little knowledge on the subject. I'm set on this case(phantom 410). It has 2 USB 3.0 plugs on the front so I'm wondering, do I need a Mobo that has these 2 plugs in order for the case plugs to work. Also I have read that both plugs from the case are male and that most Mobo plugs are male as well. Will this cause a problem.
Adrian Ocampo
It would not work if you dont plug it in a USB 3.0 Header. You might want to buy a PCI Express USB 3.0 Internal Header.
