[SOLVED] The screws for my CPU cooler backplate are not long enough for my mobo.
Aug 9, 2020
4
I got a coolmaster 212 Evo, to use with an x299 aorus gaming 7 pro. The product page said that it fits with the lga 2066 socket, but when I tried to install the backplate the screws were not long enough. After contacting customer support they just gave me a refund, but I would preferably want to still use this cooler. Is there a workaround or a way to buy longer screws?
Backplate is not required for LGA2066.
You screw H-type bolts right into those holes in the socket.
(read manual carefully)
Show some photos.
Seems like LGA2066 installation doesn't require use of a backplate.
Read the manual.
Images (sorry they are low res):
https://cdn.discordapp.com/attachments/720756729142444063/742002070202220574/image1.jpg
I have read the manual, and I was a little confused on why it didn't say LGA2066 on the parts pertaining to the backplate. I heard that if you don't have a backplate it can cause your motherboard to deform, so I assumed I needed to install it.
