Ok, so I decided to build a PC. I got a used RX 570 for around 130 bucks as i remember. When I finished the build and powered on the PC, everything seemed fine. Yesterday I went to download and install the drivers for the gpu. (yes, i downloaded the correct ones) And during the installing process, the installation stopped. Also, when i go to the device manager, there is a small yellow sign next to my gpu. Every time i try to update the drivers, it ends up unsuccessfully. I can't run any games, and in the properties of the gpu it says "This device isn't using any resources because it has a problem", and it also says "code 43".
Someone please help me fix this! Thanks!
